Стиральная машина LG-1090FB - ошибка SE
berrza
После закачки воды при первой же попытке прокрутить барабан загорается код ошибки SE. В инструкции про этот код ничего не сказано. Это серьезно или можно своими руками что-то сделать (программу перезагрузить или еще чего)?
«SE» - SENSOR ERROR
The connector (5-pin, male, white) in the wire harness is not connected to the connector (5-pin, female) of hall sensor in the MOTOR.
Reconnector or repair the contact in the connector.
• The electric contact between the connectors
(5-pin, male in the wire harness and 5-pin, female in the hall sensor) is bad
or unstable.
Reconnect or repair the contact in the connector
• The connector (6-pin, male, natural) in the wire harness is not connected to
the connector (6-pin, female, natural) of PWB ASSEMBLY (Main) or the
electric contact of connectors is bad/unstable.
• The electric contact between the connectors 6-pin, male, in the wire
harness and 6-pin, female in the controller (Main) is bad or unstable.
• The Wire Harness between hall sensor in the MOTOR and PWB
ASSEMBLY (Main) is cut (open circuited).
Repair/replace the damaged WIRE HARNESS
• The hall sensor is out of order/defective.
Replace the motor
• The controller (Main) is out of order/defective.
Replace the PWB ASSEMBLY
Сами решайте - сможете или нет сами сделать....
or unstable.
Replace the motor
