подскажите аналог транзистора stb1277L
novichok2012
Интернет сломался?
STB1277(PNP) TO-92 Bipolar Transistors 1. EMITTER TO-92 2. COLLECTOR 3. BASE Features Audio power amplifier High current application High current : IC=-2A Complementary pair with STD1862 MAXIMUM RATINGS (TA=25? unless otherwise noted) Symbol Parameter Value Units VCBO Collector-Base Voltage -30 V VCEO Collector-Emitter Voltage -30 V VEBO Emitter-Base Voltage -5 V Dimensions in inches and (millimeters) IC Collector Current -Continuous -2 A PC Collector Power Dissipation 625 mW TJ Junction Temperature 150 ? Tstg Storage Temperature -55-150 ? ELECTRICAL CHARACTERISTICS (Ta=25? unless otherwise specified) Parameter Symbol Test conditions MIN TYP MAX UNIT Collector-base breakdown voltage VCBO IC= -100uA, IE=0 -30 V Collector-emitter breakdown voltage VCEO IC= -1mA , IB=0 -30 V Emitter-base breakdown voltage VEBO IE= -1mA, IC=0 -5 V Collector cut-off current ICBO VCB= -30 V, IE=0 -0.1 uA Emitter cut-off current IEBO VEB= -5V, IC=0 -0.1 uA
http://tranzistor.biz/tranzistor.php?tranzistor=57658
Аналоги и замена для биполярного транзистора STB1277L:
SRC1212E , SRC1212EF , SRC1212M , SRC1212S , SRC1212SF , SRC1212U , SRC1212UF , SRC1219 , SRC1219E , SRC1219EF , SRC1219M , SRC1219SF , SUR481H , SUR489J , SUR498H , SUR510EF , SUR512EF , SUR526H , SUR532H , SUR536H , SUR541EF , SUR545J , SUR547J , SUR552J , SUR566EF , 2SA1979S , 2SA1980M , 2SA1980UF , 2SC5342U , 2SC5343UF , 2SC5345M , 2SC5345UF , BC818F , BC846UF , BC848UF , DN050S , DN200F , DP030S , DP100 , SBC328 , SBC338 , SBC558 , SBT2222F , SBT2907AU , SBT3904UF , SBT5551 , SPS8050 , STB1277L , STC128M , STC4081 , STC5551F , STD1862L , STN2907AEF , STN2907SF , STN3904S , STS1979 , STS9013 , STS9015 , SUT460M , SUT480H , SUT488J , SUT562EF
novichok2012
novichok2012
novichok2012
